I assume you have a manual/gear transmission since the HST has an independent PTO... Short answer, sorry, no. BUT you can use an over-run PTO coupler... which might help you some. It doesn't allow a mower to transmit power back through the transmission.
Overrunning Clutch-PTO Overrun Clutch
An overrun coupler attaches to a tractor's PTO shaft and drive shaft of the implement. It has a 1-3/8www.agrisupply.com
II have had an L2800 for 15 years…great tractor. Non HST model. Can anyone explain why a double clutch would be desirable? Thanks.
