First time poster here. I have a 2020 L3560 with 200hrs. Occasionally the machine starves for fuel (seems to happen more with <1/4 tank). It tries to run but dies. Ive replaced the fuel filters and emptied my separator without luck.
The only thing that works is loosening the fuel cap and taking the line off the separator and blowing air back into the line until I can hear bubbling in the tank. From there it may run for a week or a hour. Not sure if there is a filter/sock in the tank, but that seems to be where my clog is. Curious if I should drain/flush the tank (not sure if there is even a drain plug). Also, not sure if my “clog” would even loosen up by pouring in fresh diesel/re-draining.
Im trying to avoid taking it to the dealer to drop the tank, etc. All suggestions would be greatly appreciated!
