BH92 Boom Hydraulics Weak
OttoOrange
L3560 with LA805 and BH92
Jun 12, 2019
Nova Scotia Canada
I have been having so much fun pulling stumps I forgot to update this thread.
The service guy at shop found a restriction in the inlet plate of the first control valve (I assume that was the hydraulic thumb control) causing a pressure drop of 1000 psi. Hence the 1600 psi reading earlier was correct but obviously too low. The plate was replaced and the tractor returned 2 days later. A totally new backhoe experience. I can move the rear end of the tractor around using the backhoe, which wasn’t possible before. I have dug out a stump that was too big to pickup and had to drag it to it’s new resting place.
Thanks for everyone’s input and thoughts. Great forum!!!
IndMan
MX5400, BH92
Jul 22, 2024
SC
I know this thread is old but I am having the same issue and I also have the hydraulic thumb. Would it be possible to describe the issue with a little more detail? Was the plate pinching a hose?
3,806
That description is pretty garbled.. Sounds tp me like the restriction was in the linlet area of one of the valve sections.
