I am having a serious problem understanding what you are saying. What do you mean by the all the lever does is "manually tries to pull up the rear"?yes, thank you, that is the one I have always used. It literally does nothing except manually tries to pull up the rear.
Is there no other levers that could put it in 'neutral' or anything? NOT normal neutral, but obviously rear is not working.
When you pull back on the lever the arms should raise up. When you let go they should stop and stay where tje are.
