Hello, I have an Avant 635 with the Kubota V1505,
It has been leaking oil, and I suspect it is the main seal, as it is all wet but that is besides the point. It was brough out onto a jobsite and the guys were told to keep an eye on the oil level as to not run it dry. They ended up putting all 10 ish quarts into the motor, along with the 5-6 it already had. I drained it back down to operating level, but now whenever the motor is above 2500 rpm, it starts to burn a lot of oil, misfire and die. The idle is lower than it was, but from 1000-2500 rpm it runs fine.
If anyone has any sort of suspicion or help to offer it would be much appreciated
Thank you
Thank you
