Want to buy L2502 but cold start has me re-thinking
Bryston
Hi, am about to buy the L2502 till I came across this, am in Canada, someone said they Shimon the pump, am not sure I like that fix.
Anyone know if this issue fixed?
Am thinking to look at LX2620 again.
Thanks
Daferris
LX2610
Nov 23, 2021
475
395
Mid-Michigan
Thanks
In a nutshell of you break the seal on the pump to change the timing or adjust the fuel. You can probably be assured that the warranty on the motor will be voided... That said. You can do it it's just that if something breaks on the motor it will be on your dime to fix it.
TJArkie
Arkansas
Thanks
I posted the same issue above and I pulled the trigger on the new L2502. No issues whatsoever and the dealer has not had a single one with that issue. I don’t have a ton of hours on mine but it starts right up and runs great. Zero issues so far and would recommend it without hesitation.
