Buy cheap, get cheap
ctfjr
L3800HST
Dec 7, 2009
1,820
2,150
central ct
Everyone should know that. I certainly should. But sometimes we get seduced by a really good price. . .
I needed an 18" auger for my tower project. Just have to drill 4 holes. I went to put on the auger extension for the 3rd hole and found this:
Will be taking it to a welder friend to reinforce those bolt holes
4,009
Looks like they put the wrong SKU label on it. Clearly says “Heavy Duty” on the same sticker the SKU is on. Evidence indicates otherwise…
Sidekick
Kioti CK2620SE cab, RTV-X, BX3260, Z726XKW-3-60, Deere 4100
Jul 29, 2023
346
294
N.Y,
Made from genuine Chinesium. Probably a label that said 10 hp max missing.
lynnmor
B2601-1
May 3, 2021
1,401
1,105
Red Lion
Do you know if those bolts are intended to shear to protect the rest of the system? There is serious torque developed by a large auger running at low RPM.
ctfjr
L3800HST
Dec 7, 2009
1,820
2,150
central ct
I have a shear bolt on the pto shaft. It should go first. It's 1/4" grade 2 or 5 iirc, the bolts through the auger shaft are 1/2".
