2012 BX25DLB 320 hours.
Scratching my head with a fuel problem. Tractor has started losing RPM while under heavy load, namely mowing uphill with the 60" deck. Drops RPM, spits and sputters and sometimes stalls out.
I've changed both fuel filters, lift pump and some questionable lines, no difference.
With the engine not running, I noticed the filter bowl wasn't filling up completely (not sure if it should) and the lift pump was constantly running. No external leaks, so I wondered if it was pushing it through the return. Sure enough, whatever the lift pump was pushing was going right back to tank through the return. Should that be, or should the lift pump prime everything before the injection pump/injectors then stop pumping until engine is started?
If that is normal operation, or do i have an injector leaking by or something? Any other thoughts? Just replaced a couple other lines and fittings and going to try it again to see if the problem persists.
Any recommendations would be more than appreciated!
Thanks,
Pat
Thanks,
Pat
