2009 L2800 Kubota hydraulic oil.UDT2 or not
racer86y
2010 Kubota L2800
Sep 7, 2022
32
Kingston,Ok.
I went to all the stores and auto parts around and all they have is Kubota UDT.Is that good and UDT2 overrated?:rolleyes:
3,881
I doubt any of them had UDT of any type. They had some brand that listed UDT on the back label.
Is your tractor gear drive or HST?
Tarmy
L2800, BH76A, FEL,box scraper
Nov 17, 2009
428
310
Lake Almanor, Ca
I have a 2008 geared L2800 and have always used Kubota UDT…good so far…(y)
5,656
Mystik JT-5
You will only get real UDT, and SUDT2 from a Kubota dealer.
3,881
I just paid $140 per pail for the SUDT2 that is going into my L3901 HST at the 400 hour service. I made the choice to spend $28 per gallon because SUDT2 has documented performance advantages over other formulations that are of (marginal??) benefit in an HST tractor.
I have two pails of Traveller Premium UTF sitting next to the SUDT2 that probably cost $15 per gallon. I have been using that in my B7200DT for 30 years.. I made that choice because it is a lower cost generic formulation very much like standard Kubota UDT and there is no real adavantage to spending more for a brand name with similar properties.
Kubota SUDT2 is a somewhat unique formulation with just a few equivalents which are all similarly priced. Kubota UDT is not at all unique and the shelves are filled with very acceptable and much less expensive equivalents.
racer86y
2010 Kubota L2800
Sep 7, 2022
32
Kingston,Ok.
3,881
after searching around i found Kubota had super UDT@ cheaper than the rest.So i have Kubota hydralic oil and filters in my tractor.Super UDT@ was 115 bucks for 5 gallons.
Well thats a great price on SUDT2 but not cheaper than the rest.
The front axle is not connected to the hydraulic system and has its own fill plug.
racer86y
2010 Kubota L2800
Sep 7, 2022
32
Kingston,Ok.
I watched several u tube videos and nothing was said about that.Is that the only 2 places to fill from? Does it use hydraulic oil too?
3,881
