3PH Height Adjustment Stop
rcsracing
LX3310, brush hog, box blade, pallet forks, front blade
Jan 22, 2022
26
17
Pittsburgh, PA
Hi folks,
The thumb screw part vibrated lose when I didn't have it tight one day. At least a washer and the bottom clamp piece are gone.
I can't seem to fine them on Messicks/Kubota parts diagrams.
Kubota - https://shop.kubotausa.com/oemparts/a/kub/609195f287a86614f81b7f67/f14000-position-control-lever
I did find a few posts here about switching that thumb screw to a quickadjust from McMaster, here is the image they used (I think this was an older L) - https://www.dropbox.com/scl/fi/a3ue....JPG?rlkey=b24jy6d5xu8922jrlo5voqceu&e=1&dl=0
I need part 120 on that one, but transposed to an LX3310 part number.
Can someone point me in the right path?
Thanks!
-Rick
Mitjam
Jan 14, 2013
159
132
Edmonton, Alberta, Canada
Hi folks,
Thanks!
Hey there my phone isn’t letting me send the
Hi folks,
Thanks!
SCREW
$4.06
Hi folks,
Thanks!
-Rick
I think this is what your looking for ?
rcsracing
Jan 22, 2022
26
17
Pittsburgh, PA
Is there a 3rd piece? The drop box link about looks like that stopper is on top, vs a keyed bottom piece.
2,682
1,423
Your LX is different from that L picture you dropboxxed. There is a flat washer on top. You could booger the thread on the knob after you assemble it to keep from losing that part again.
rcsracing
Jan 22, 2022
26
17
Pittsburgh, PA
thank you! I have no idea why that's not shown on the Kubota parts diagram for an LX3310.
2,682
1,423
Actually, that diagram I posted is for the LX3310. It's considered a part of the body, not the control valve :rolleyes:. There are other instances, I'm convinced one part I was looking for once is not on any diagram.
2,742
I have one of those on my B2910 with position control, but I don’t think I’ve ever used it. Just curious but what to use it for?
Matter fact, next time I get down to the tractor shed, I’m gonna have to look and make sure it’s still there. 22 years since I bought that tractor…
MOOTS
MX6000
Jun 27, 2019
1,856
2,105
Canton, Georgia
Clamping Handle with Threaded Stud, Black Powder-Coated Aluminum, M6 x 1 mm Size, 20 mm Long Thread
4,070
Only time I use it is bush hogging. Before starting, stop on a flat area, set height of front of cutter a bit below rear of cutter, set the stop up against the 3 point control lever. After that, can raise cutter as needed and set it back down exactly at height it should be by dropping the 3 point lever to the stop. Now that I’ve done this quite a few times, I can set mine on about 2.25 on the scale for the 3 point lever and run it.
Maybe there’s some other practical use for being able to repetitively drop the 3 point to a set height. If tractor doesn’t have position control, not sure it would be useful for anything.
