I was box scraping our road the other day and one of my frontwheels, spindleand all fell off. I had a mobile mechanic come out and he pulled the wheels assembly apart and found only a part of one of the two clips or keys that goes into the groove in the spindle. One of the thin bearing spacers was actually pushed back into the housing and not pressed against the lip on the housing that the bearing rest against. He replaced both of the clips/keys. Installed a new shim and put everything back together. When the front wheels are off of the ground you can grab the wheel and slightly rock it back and forth. The otherside has no play in it. Does anyone know what needs to be done to get the play out of of that wheel. The two closest dealers are over and hour away and to be honest, aren't worth going back to. Any help would be appreciated.
