If I park my tractor with the loader in the full up position over night, in the morning it’s halfway down. The loader also seems like it’s weaker than it used to be. Any suggestions on how to troubleshoot and diagnose the issue? Thanks!
You are expecting too much. The loader is acting normally.And I have no experience with hydraulics so don’t know where to even start. Fluid is full and looks clean. No external leaks.
I have a similar problem. I suggest that you see Alice, just don't go to Hellen Waite!If I park my tractor with the loader in the full up position over night, in the morning it’s halfway down. The loader also seems like it’s weaker than it used to be. Any suggestions on how to troubleshoot and diagnose the issue? Thanks!
Urologists deal with it as well. My uncle is Dr. Assman.Leak down…it’s a “thang” with hydraulics!
++++2It's a really,really BAD idea to leave ANY loader 'up' when you're not operating the tractor.
Not something I normally do, but I was using the tractor to hold something in place over night. When I normally park it I let all the hydraulic pressure off the loader and 3pt.++++2
Never store any machine with any component raised. It is a terrible accident just waiting to happen. Even if it does not settle on its' own, imagine a couple of kids screwing around. One under the bucket looking at bugs and another fiddling with the controls. A 1 in a million but that is 10X too many.
the video I just watched shows a trick to tell if it’s the bucket curl or lift booms or control valve that’s leaking by swapping line positions into the valve block. It didn’t sound like noticeable leaking over a short amount of time was normal.I just had the cylinders on my loader rebuilt by my local dealer. I parked the tractor with the loader about 2" off the ground to just to test it. When I went back to use the tractor after 4 days the loader had not moved at all.
ALL spool valves leak and thats what you are seeing.the video I just watched shows a trick to tell if it’s the bucket curl or lift booms or control valve that’s leaking by swapping line positions into the valve block. It didn’t sound like noticeable leaking over a short amount of time was normal.
When I get a chance I’m going to grab a test gauge and also try the swap trick to try and figure out if some seals need replacement. Hopefully it’s not too big a job.
Tell me about it! I had a bad “walnut” taken out of my lower belly a year ago…had to have a special “bag” installed to catch my leaked down “hydraulic fluid”Urologists deal with it as well. My uncle is Dr. Assman.
The good news is you lived to tell the tale.Tell me about it! I had a bad “walnut” taken out of my lower belly a year ago…had to have a special “bag” installed to catch my leaked down “hydraulic fluid”I wasn’t under warranty either!
After a little asking around, it kind of sounds like leak down in the curl cylinders is more common than in the lift cylinders. Does that sound right?You are expecting too much. The loader is acting normally.
To evaluate the possible loss of power you need to invest in a 3000 PSI pressure gauge - $20.
Your lift cylinder seals could be blown to hell and it would not change anything. They are not needed to hold the loader up.
Swapping
Leakdown on the lift cylinders is caused by imternal spool leakage in the valve.After a little asking around, it kind of sounds like leak down in the curl cylinders is more common than in the lift cylinders. Does that sound right?
Any recommendations for a gauge and how to figure out what adapters I'd need for my machine?
Thanks
Personally I think a gauge is essential equipment for anyone working on actractor. But I am wondering what the problem is that you are planning on using ot on.After a little asking around, it kind of sounds like leak down in the curl cylinders is more common than in the lift cylinders. Does that sound right?
Thanks
