Mid PTO shaft Repair
1011hans
B2910
Oct 9, 2016
Spokane, Wa
B2910 Kubota with B2761 subframe and B2762 Mid PTO kit. The shaft is slightly bent so I want to remove and have straightened. However the shaft will not slide back far enough on the center spline to clear the PTO spline. It looks like I would have to unbolt the entire sub frame or unbolt and remove the PTO housing.....Really? Any better ideas?? Thanks
Dustball
2016 B2650HSDC
Sep 15, 2023
252
133
Hudson, WI
Try loosening the set screws on the bearings to slide the splined shaft towards the front.
