I've got a 2015 B2620 and my FEL is sometimes not responsive to raising. Curl function works fine
I switched the FEL hoses to the curl function and same issue and when I try I can see a small leak at the connection point to the cylinder (not the rod end) if I relieve the "up" pressure the leaks stops, its like the cylinder is locked in position.
The funny thing is if I restart the tractor everything works fine until I attempt to load/lift something heavy.
(and yes my 3point hitch is on lowest setting)
Rock
Rock
