B7610 Steering noise
EdwardsKev
Kubota B7610, Betstco Flail Mower, 5ft HOWSE bush hog
Mar 10, 2023
9
Spartanburg South Carolina
So over the last few days while using my tractor I've noticed a noise when Im turning. Any ideas on what it could be? Kinda sounds like power steering noise. I'm not sure how this thing works for turning. I would assume it all uses the same tank for hydraulics? Anyone have a diagram of the tractor?
TIA
Kevin
woodman55
L6060HSTC, RTV 1100
May 15, 2022
910
704
canada
What type of noise. Hyd ? tires rubbing, sweek from dry pins? Lift the front end and test it again.
EdwardsKev
Mar 10, 2023
9
I would say hydraulic noise. I will lift the front end and steer and see if I can hear it and get a video. It's not a tire rub, I checked that. 👍🏻 Pins, I will check on that.
EdwardsKev
Mar 10, 2023
9
Definitely hydraulic, only happens when moving forward and turning at the same time. I assume these things don't have a separate steering pump?
