L4150 Lost Oil Pressure
nlefmann
L4150D
Jul 30, 2017
Aromas, Ca, USA
Hello all. Looking for some wisdom. I was mowing much of the day yesterday with my L4150 and everything fine. Then in the early evening I noticed the oil pressure light come on. I also have installed a gauge that also read zero. What could have happened? (The engine still ran).
StephenR
27
9
Kentucky
You could have several different problems. From as simple as 2 failed sensors or as complex as a failed oil pressure pump. First check the oil level and all of the oil lines for a leak. If the oil level is full, I would not run the engine until you make sure you have pressure to pump oil to the engine bearings.
Steve.
nlefmann
L4150D
Jul 30, 2017
Aromas, Ca, USA
Thanks Steve. I'm afraid it's not a sensor since the secondary oil pressure gauge I installed is not electric and has worked fine until this occurred. Engine oil is full although looks dirty. I will change oil & filter but still afraid to run it any more until I figure out what happened. Looking for help!
1,114
I would assume that the oil pump is not working. It could be the pump or what drives the pump is broken. It might be simply that the oil pickup broke off somehow.
See here for illustrated parts list
The pickup is in the oil pan section and the pump is in the crank case section. The pump appears to be driven by gears and is under a front cover of the engine.
From what I see I would drain the oil and drop the oil pan first to verify if the pickup is still intact and the screen on it is clean or clogged. Beyond that I would probably replace the o ring on the pickup tube if it seems it is loose at all.
If nothing there the move to the front cover removal and see what is going on behind there with the pump. That is much more work to get to (I assume).
nlefmann
L4150D
Jul 30, 2017
Aromas, Ca, USA
nlefmann
L4150D
Jul 30, 2017
Aromas, Ca, USA
Thank you Russell. I was afraid that's what I would hear from the Orange sages! No time right now so it may be a while before I post what I find.
5,569
If the oil pump has failed it will be the first one I've ever seen fail.
I've seen 20K hours on these engines and the oil pumps are like new still.
It's more likely that the relief valve.
Super easy to get to and check.
nlefmann
L4150D
Jul 30, 2017
Aromas, Ca, USA
Thanks Wolfman - I was just looking at that part and wondering if it could possibly be related to my issue. Can it be cleaned or should I buy a new one?
nlefmann
L4150D
Jul 30, 2017
Aromas, Ca, USA
Today I installed a new relief valve and o ring, changed the oil and put on a Kubota filter. Had high hopes but still no oil pressure. Should I drop the pan next?
5,569
Yes I would drop the oil pan next and check for pickup issues, then if you still don't get anything you'll have to open it up even further.
Have you opened up the oil port pressure port and cranked or run it to check for any oil flow?
nlefmann
L4150D
Jul 30, 2017
Aromas, Ca, USA
Wolfman - I have to admit I don't know what/where the oil port pressure port is. Are you talking perhaps about removing the Comp Relief Valve at the filter or should I be looking somewhere else?
4,990
1,709
on the side of the engine there are a few plugs. Some of them are "drive-in" plugs, as some call them "freeze" plugs or "welch" plugs. They close off intersecting oil passages, and some of them are on the suction side of the oil pump. If one of those falls out, it will have zero oil pressure. I've seen this numerous times on some of the L series (L35 comes to mind....). Best I remember, RH side of the engine near or on the gearcase.
nlefmann
L4150D
Jul 30, 2017
Aromas, Ca, USA
Thanks so much. I'll definitely give both sides of the block a good close look and let you know what I find. BTW I've never encountered a freeze plug that did not seal off a water passage. Never knew that they were also used for oil passages.
5,569
Pull the oil pressure sensor off and see if you get any oil flow.
1,114
@North Idaho Wolfman is referring to the point where your oil pressure gauge line attaches to the engine.
If you remove the small tube at the engine attachment point and crank the engine there should be oil that exits that hole. I would avoid starting the tractor, just crank it but not start it. If it does start then turn it off quickly or you may have a mess.
Depending upon where the point is you might be able to cover it with a rag to prevent the mess.
