M6060 error 3
RMartin758
M6060
Jun 27, 2024
Louisiana
I have a M6060 aprox. 2014. Tractor was running fine today until I turned it off for a few minutes. When I cranked it back up was showing error- 3 and engine warning symbol. Would not go above idle. Any suggestions would be appreciated.
4,351
yeesh, THAT ( actually ALL error codes ) should be listed in the owner's manual !!
If it isn't ,then shame on Kubota !! NO reason for it NOT to be in there.
RMartin758
M6060
Jun 27, 2024
Louisiana
I found the code description. (acceleration sensor main sub phase shifting trouble) I'm assuming trace wiring checking connections and for shorts would be my first step. I'm not sure where the sensor is located, or if will need a dealer to reset. Was able to locate a previous post with the same issue, but no resolution was ever posted.
3,285
1,759
Explain that to Toyota. Trouble codes not showing on ODB2 and proprietary diagnostics ports and subscription only access should be illegal for automotive.
New profit centres for OEM's. So they can charge $500 to spend 60 seconds to plug in a laptop and turn off limp mode on your big rig pollution controls system.
4,351
OBD2 was a good start but fails. Unfortunately it lacks the ability to tell you WHICH specific sensor has failed. Something very,very easy to do. BTDT. Have 30 sensors on one wire(R&D test was 128) and I can tell which specific sensor has failed and isolate it from the rest,keeping the system 'up and running'.
