So I think I found my problem. When looking at the blade hubs I noticed the center hub doesn't appear to be fully seated in the spindle. I removed it and cleaned the surfaces but it still won't sit down. I can't even get the snap ring back in, the hub won't slide far enough to expose the groove. Any suggestions on where to go from here? A little persuasion with a hammer made no difference...
Edit - well that wasn't the issue. I got the center spindle put back together and torqued per the procedure in the service manual. Blade's still hitting. I'm going to take the right side spindle apart next to check bearings and look for anything bent.
