trash in fuel
rovdrew
BX 2670RCK60B-23BX mower deck. LA243A Front loader
Apr 21, 2024
Louisiana
BX 2670 has been stalling after 1 to 2 hours of use. narrowed it down to fuel restriction. Had already changed fuel filters, so now drained tank with a pump. I then removed the first filter. No fuel came out of the outlet hose when I removed the filter. Blew compressed air in hose and 1/2 gallon of fuel poured out. Filled tank with water and emptied with shop vac several times. Got a June bug and smaller stuff. Now drying tank by blowing hot air with shop vac.
Question what is best way to completely dry tank before adding new fuel. Are there additives? what is a fuel snake and do they work? Also does it make sense to install a water Seperator fuel filter in place of the first filter?
Ktrim
Dec 23, 2020
403
283
Nazareth Pa
Let it sit for a few days. Or run isopropyl alcohol through it. The alcohol should grab the water and evaporate it out
yorkies77
Kubota BX23S
Jun 7, 2020
52
46
Idaho
I bought a cold coffee and tea filter that fits in a mason jar and it works great for a filter for the fuel tank on my bx23s.
4,713
curious, had a look at the tank online.... best plan ...remove it !
Had similar problem with my BX23S tank ( 3 'chambered' ) and really it's unlikely you can get 100% of the crap out while in the tractor. You can easily blow/slosh the bad stuff here ,there, everywhere except OUT of the tank.
Yes it could be a pain.. the BX23s was 'entertaining ' to say the least but after 5 YEARS ( 1000+ hrs) I've had ZERO issues. Pulled the tank, flushed with water, flushed with alcohol(winter squirter fluid...),blown out with compressed air, left in hot sun for 5 hours.
OK, maybe overkill BUT I'm 100% SURE there ain't NOTHING in the tank !!
I did install one of those cold brew coffee filters, $12 CDN from TEMU, less than 1/3 of Amazon's price !
