Various stages of incompletion.
mcmxi
5,774
NW Montana
I don't know if people are familiar with the company SCANSTRUT but they make really nice cable glands that offer a waterproof solution for passing cables through bulkheads, consoles, caps, etc. They come with grommets that compress as the outer trim is installed which seals around the cable or wire. They include a solid grommet that can be drilled to suit. I had to run two wires from the jack plate motor and two wires (in a single jacket) from the jack plate height sensor into the interior of the boat. Following SCANSTRUT instructions, I put the solid grommet in the freezer and then drilled three small holes for the three wires.
The local Kubota dealer had some nice spiral wire/hose loom in stock so I used a few feet for a factory look. The light grey piece is screwed to the hull with a waterproof gasket between it and the hull. The outer trim rim attaches to the plastic mounting plate with machine screws. There are four nuts in recesses on the back side of the mounting plate. All in all a very nice solution.
mcmxi
5,774
NW Montana
Oh yeah, talking of boat names, a friend sent me this a few weeks ago.
A bar in Missoula that has a poker room has a plaque that says "Liquor up front, poker out back!" 😂
3,222
I do miss my boat, I miss my Harley , I miss my Plymouth Coupe, I miss my youth,, old age sucks !!!
mcmxi
5,774
NW Montana
I wish I had more time to enjoy where I live and my hobbies and interests. I should have moved to Montana 20 years ago rather than 10 years ago! Hawaii wasn't a bad place to be for 23 years but I should have moved away sooner.
