Hello,
I have been looking all over the internet for information about Kubota GL 320 hydraulic system without much luck.
I need to add rear remotes to my tractor but I'm quite inexperienced in tractor hydraulics and machine is quite compact for tracking down all hydraulic parts.
Can anybody help to point out from where could I get supply to valve from the pressure side of the pump?
Or is there already manifold block installed to GL series from the factory?
There is one pressure side pipe running from the bottom of the pump to the bottom of the seat (right side). Could this be PB port on the pump and I would have to cut it?
If someone has workshop manual with schematics then I would really apperciate it. I only have user manual which is in japanese.
Tractor does not have loader so I can't get any supply from FEL valve.
Thanks.
Thanks.
