No Start. Trouble code PO 605
Ken "Big Dadty"
2018 Kubota L4701 loader/backhoe
May 1, 2024
New t I this group. I purchased my uncles 2018 L4701 Kubota tractor with loader and backhoe. It has the PO 605 trouble code. I have tested all mini fuses on left side of tractor. I have also pulled the cover over instrument panel to expose the 3 relays on left side of instrument panel and all are good. You turn key to start and nothing. Starter will not work. The ecu above instrument panel starts making " noises" like it is running a test but no starting or engine turn over at all. Battery i took out and charged to 13.6 volts and have a green charged eye on battery and it shows 13.6 volts on multi meter. Really need to get this machine making money. Any help appreciated. Thanks
6,067
It has a ECM issue, you're going to need to have dealer work on it.
2,457
This thread may help - I hope the rabbit hole is not too deep :
https://www.orangetractortalks.com/forums/threads/l4701-p0605-code.59423/
4,793
bad news is , have to have dealer fix it,hopefully won't take a week or a month....busy season
good news, you can write off the repair bill as an expense
2,902
1,370
You should contact your dealer and tell them you need TSB-2023-035-E-R1
TECHNICAL SERVICE BULLETIN
The document is controlled electronically. Printed copies of this document are not controlled. Document users are responsible for ensuring printed copies are the latest revision prior to use.
FIX AS FAIL EXTENSION: L, M, MX-Series; Engine ECU Malfunction Preventing Machine Start
Repairs described in this bulletin may be made only in the event of a failure.
R1 Revision: Added L3301F and L4701F to the Serial Numbers Affected and ECU Information sections.
Product Line:
L, M, MX-Series
Model:
L3301, L3560, L3901, L4060, L47, L4701, L4760, L5060, L5460, L6060, M62, MX4800, MX5200, MX5800
Serial Numbers Affected:
Model
Serial Numbers
Model
Serial Numbers
Model
Serial Numbers
L3301DT, L3301HST, L3301F: 50003 to 77739, 50004 to 75744, 10008 to 10453
L3560DT, L3560GST: 30010 to 43941
L3901F: 10007 to 10189
L3560HST, L3560HST-LE: 30001 to 43953
L3901DT: 50011 to 82664
L3560HSTC, L3560HSTC-LE: 30002 to 43907
L3901HST: 50010 to 81725
L4060DT, L4060GST: 30004 to 44510
L47: 50001 to 52059
L4701DT, L4701HST: 50009 to 65829
L4060HST, L4060HST-LE: 30001 to 44561
L4060HSTC, L4060HSTC-LE: 30003 to 44557
L4701F: 10001 to 10754
L4760GST: 30005 to 42245
L5060GST: 30001 to 40197
L5460HST, L5460HSTC
30002 to 41546, 30001 to 41558
L4760HST: 30001 to 42326
L4760HSTC: 30004 to 42334
L6060HST, L6060HSTC: 30008 to 46972, 30001 to 46985
M62: 50001 to 51172
MX4800F: 10001 to 10329
MX4800DT: 50001 to 54209
MX4800HST: 50001 to 54280
MX5200F: 10001 to 10744
MX5800: 50001 to 55122
MX5200DT, MX5200HST: 50001 to 65359
Issue:
The engine may fail to start and DTC code P0605 or P0606 may appear.
Solution:
If DTC P0605 is present, replace the engine ECU with the updated engine ECU in the chart below for your unit per the Workshop Manual and carry out a manual DPF regeneration per the Diagnosis Manual.
If only DTC P0606 is present, update the ECU Software to the latest software per the chart below for your unit and clear the DTC codes (The DPK file can be downloaded from the Machine Software page on K-Service).
Warranty Information:
This bulletin applies in the event of a failure and does not constitute warranty authorization to update units without a defect in material or workmanship. File warranty only in case of failure.
Warranty Term
8 Years from retail date
(for this specific failure only)
TSB-2023-035-E
DTC code P0605 is present
1.0 hours
Only DTC code P0606 is present
0.5 hours
5,055
Product Line:
L, M, MX-Series
Model:
Model
Serial Numbers
Model
Serial Numbers
Model
Serial Numbers
L47: 50001 to 52059
L5460HST, L5460HSTC
M62: 50001 to 51172
Issue:
Solution:
Warranty Term
TSB-2023-035-E
1.0 hours
0.5 hours
Wow!
That seems incredibly helpful for the OP!
Even the suggested number of hours to be charged.
Ken "Big Dadty"
May 1, 2024
Thank you
Well I fixed it myself. Wish I would have seen the other posts before I did. But 750.00 is a lot cheaper than 3k for a new one. But I seen in answers to my post that there is a way to get kubota to pay for it up to 8 yrs from build date if I read it correctly. Im REALLY PISSED the dealer I spoke to didnt tell me about this " recall on PO 605 trouble code" unless he is double dipping and by that I mean charging me full price and also getting paid by kubota too. Thanks for info. Its running great anyhow.
ntses.ya
MX4800HST
Sep 18, 2024
MO
Mine is showing the PO605 and I'm out of the 8 year warranty. How did you fix it?
