Unleash the Lathe dogs!!!!!!! who knew?
Yooper
3901 LA525
May 31, 2015
1,464
433
NE Wisconsin
I believe we have the same lathe. The spindle bore is tapered for a number 3 Morse taper. Just make sure the spindle bore is clean before seating the center.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
761
548
canada
I have often wondered about those types of bits.
The biggest problem I have with them is my "cheapness".
When I got this lathe and tool box combo, it was "chocked full" of HSS blanks.....I probably have 2-300 of them. So I gotta at least try to put a dent in them before I trade-up. (y)
Those replaceable cutters are what the "Howees machine shop" guy was using.
2,024
Could just file a flat spot to fit under optic vs. having that gap all the way around now.
That would have been a good idea. (y)
Turning it just popped into my head and sometimes I get "hyper focused" and "getting the job done my way" clouds my thinking.
But, on the other hand, "quality shop time" is rarely a bad thing. (y)
2,024
Thanks for the info.(y)
I love that little lathe, but I sure wish it had the "quick change gear box".
They are kinda pricey, but I might try to find one.
3,512
They are called "inserts" and "indexable tool holders".
Indexable tooling is the current standard in professional shops and industries.
The inserts are most commonly made from carbide but also available in high tech, high performance materials like cermet. Inserts last longer and allow higher cutting speeds and feeds.
2,260
Looks like a job for a 5c collet setup.
