Kubota B series salvage yard
Jjona5
Kubota B6100
Apr 24, 2024
9
Crosby, TX
Hello. I have a small kubota B series salvage yard in northeast Alabama. Below is a list of what I have right now. Shipping available on most parts. Please let me know how I can help. Thank you
B6100e
B7100d
B5200e
B1550hste
B1750e
B1750hstd
B2100Hsd
B2400hsd
Bx2200d
F2400
Thank you
Daryl
Mossy Creek Outdoors
Do you have a complete d950 engine? Looking to upgrade my 6100e one day. What about a 6100e hood in nice shape?
Jjona5
Kubota B6100
Apr 24, 2024
9
Crosby, TX
I have a running d950 that runs good and has good power but does have some blowby. I don't have any nice hoods right now though
What does a 950 with some blowby run? Also which part of northeast alabama? I used to live in Oxford. I have a buddy that goes through Alabama pretty regularly...he's there now. I live in Texas though.
Shadetree605
kubota b2100
May 1, 2022
117
47
north little rock, ar
I sure don't. I have 2 b2400 of my own personal tractors and would like a spare myself. I have a b2400 and a b2100 that I know have bad hst and another 2100 I'm not sure of as engine was bad. Outside of the hydrostat unit I'd have all the other transmission parts
ok, ty for getting back to me. i rebuilt the hydro on mine, so far so good, parts for it were high dollar !. never owned , let alone worked on a tractor until i took this girl under my wings a couple yrs ago. it was so much fun splitting it..lol. the only real problem i ran into was the one large back steel plate ?, it was discontinued back then. sooo..with a little help from jb weld, some fine sanding, i was able to salvage the steel plate. if that one b2100 with the bad engine has a good hydrostat transmission ?, i wouldn't mind taking it off your hands for a good price ?.
Mountainman
L2501, B7100, B6000, BX24, B1750, B2400
Jul 10, 2022
118
37
Attalla Alabama
mossycreekoutdoors.com
That's awesome. They are great tractors. The problem is I just don't know if that Hydro is good or not and short of swapping it onto a tractor with a good engine there's no good way to know. I'm probably gonna just hang onto it as a spare and take my chances. On a side note the b7300 has the same hydro unit and sometimes you can find them cheaper as they were low hp and no power steering. Just food for thought
Shadetree605
kubota b2100
May 1, 2022
117
47
just rip it out, take it apart, you will know real quick like if its bad or not ?, the damage will stick out like a turd in a punch bowl..lol.
5,356
Looking for one of these covers:
It's a diverter valve for a B6100 / B7100
trevoroni
B6000
May 24, 2023
98
51
Hello,
Do you have a ring and pinion gear for the front axle of a B6000? I believe the part number is 66711-82810.
It is a grey market tractor but I don't think it makes a difference.
And if you do, do you ship to Canada?
Mountainman
Jul 10, 2022
118
37
Attalla Alabama
Hello,
Well I take that back. I do have that. It is the same as a b7100 which I do have.
motorhead
2009 B3200, 2007 Dodge/Cummins powered Ram 2500 395hp
May 17, 2012
431
25
Atascadero
Mountainman, I don't know if my post went through.
I am looking for the radiator "Bug and debris" screen that goes in front of the radiator of a B6100, B7100 radiator. DO you have one? If not , do you have one I could adapt? Thanks, Chris
Mountainman
Jul 10, 2022
118
37
Attalla Alabama
Yes sir I have one and I replied to your message. Thank you
Jack
B8200 BF300 FEL, 4530 Backhoe
Dec 20, 2010
Aurora, Ontario
looking for a front rim for a B7100 believe 8" x 12" 4 bolt (old style Unit ) , also a short block for a d750?
Mountainman
Jul 10, 2022
118
37
Attalla Alabama
I don't recall there ever being a 12" rim 8" wide in the 4 bolt pattern. There were some rare 10" 4 bolt in a wide but never seen a 12. The 2wd is a different bolt pattern but there were several wide rim's for that. The 4wd 7100 for a 12" rim is a skinny to run a 6-12 ag tire. I do have a good short block d750. It had low compression on 2 cylinders. I just removed the head the other day and cylinders looked good so may be able to hone it and put rings in it. I did have it running and it sounded good.
