Will a B2779 sweeper fit a b9200hst?
5,304
The issue your going to have is they never made a shoe hitch for that tractor.
That tractor also takes a subframe to make it work and almost all the shoe hitches were frame mount.
Then you will have to fabricate the Mid PTO drive for it, and those parts are not easy to find.
philruff
B9200hst, ZD21, MX5200
May 29, 2021
Northern Illinois
thank you for this!
I should have mentioned that I have the Kubota front mount snowblower on the b9200hst now. I have attached a picture of the snowblower….
If I purchase this sweeper, I have no problem robbing the parts from the snowblower. Thoughts?
thank you!
5,304
thank you for this!
thank you!
Excellent you are way ahead of the game!
Ok I would get a shoe mount and alter that to subframe except the shoe.
That would give you the best of all worlds, as you could use both implements.
