What kind of ferrule/nut arrangement is this?Yet another third function outlet. I am in the process of adding this to the LA525. Would have finished it today but I ran put of tube nuts and sleeves....
Two things that are a little different on this one are the one hand push/pull connect under pressure couplers which are mounted on a DPOCV.
I have this grand plan to run 3rd function hard lines down my loader arms. I have the four for the FEL I took off that were all bent up where they went across the cross tube. So I was thinking about cutting the bottoms off of two of them and brazing something on to install QC's. The tops already have #6 JIC, so I can run short hoses to my valve.
I like the mounting block you have. I might can do something similar. It's pretty crowded down there with the lines, hoses, and bucket leveling linkage. And I still need to be able to swing the grill guard down.
