Two part question.
I have an ‘84 B7200HST.
First part-
I have around 450 of ballast on the 3 point. When I set the 3 point about a foot off the ground, the loader will start to lift when I push the loader control valve to the float position. Obviously the loader and 3 point are operated with two different levers, so what would cause this and what would the remedy be?
Next part-
When I bought it 6 years ago I had to replace the loader control valve as the original one had failed Ang vise grips were used to control the roll.
The Kubota OEM valve was a bit too pricey so I purchased a prince 8gpm two spool valve. I’ve never been happy with its performance, as it is very jerky compared to the original valve. Is the less than smooth operation attributed to an inexpensive valve? If so, can anyone recommend a valve that’s smoother but not as pricey as the Kubota?
Thanks in advance,
Mike
First part-
Next part-
Thanks in advance,
Mike
