g_man
Feb 3, 2023
213
961
NE Vermont
Had to take care of more heavy spring snow this morning. We got about a foot up at the house. It was elevation dependent. When I got down the looong hill to the town road there was only about 6". The road was soft and muddy so I shortened the float chain and ran the plow like a dozer blade. With it angled to throw snow to the left the FEL lever gives me raise, lower, drop right edge with dump, drop left edge with curl. I try to get close to the gravel w/o turning it up. I go slow and it take practice.
My wife took a short video on her phone.
https://youtube.com/shorts/pCL748w7QS8
gg
Reactions: 6 users
5,143
I spent about 2 hours trying to get the loader back onto my tractor (BX23S) One side always doesn't want to go on correctly and I don't know if the loader arms are the problem or the operator's error.
5,129
I put all the heavier scraps of iron I have laying around on the landscaping rake and ran it up and down the runway plus the trails I ride my bikes on. The extra weight really helps in getting the results I'm after. I also have a 100 year old harrow that I can drag around, but the rake is easier to manuver. View attachment 125704
Quick right trurn after TO?
Heavy, heavy Spring snow, 15-17", blowing hard to tell. I had to bust out of the 450' driveway. It was tough going on the uphill.
Hell,......It is already melted!
Summer is coming!
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,070
3,285
gg
It's like you are pushing sand.
flyidaho
L 3301 HST
Feb 28, 2017
428
253
IDAHO
Summer is coming!
No turn required, as the mountain drops away for 1200' vertical before the valley floor, it's much easier and safer than taking off a flat and level runway.
5,129
"mountain drops away for 1200' vertical"
"much easier and safer than taking off a flat and level runway".
Kinda depends on how close end of runway is to 1200' drop off.
fatjay
Kubota B8200, B7200, ZD21
Nov 12, 2016
319
169
Eastern PA, USA
Almost had a very bad day when moving material in the bucket, so I decided to make a mount for some rear suitcase weights.
I used the 3pt arms and took some angle iron and welded wings onto it and drilled some holes so I could bolt it to the arms. The goal was to keep it as tight as possible since I need to get in and out of some pretty tight spaces.
Found some weights that matched my tractor perfectly on marketplace, too. 55lb each, I now have another 275lb on the back.
Reactions: 11 users
Nicksacco
Sep 15, 2021
698
412
Bahama, NC
Very cool!
6,284
That's getting it done.
Looks like the chain attached to the rebar going through the hole in the weights should be going in the downward direction. That would help keep the weights in place, if there was ever an occasion for them to try to lift out.
fatjay
Nov 12, 2016
319
169
Eastern PA, USA
The 3pt arms drop when the tractor is off and all the weights fell off with quite a bang. It's just holding them up. I'm looking for another way to secure them going down
6,331
Driveway was in decent condition, but needed some high/low spots smoothed out.
Boxblade with a long top link is my go-to. We’re at the bottom of a hill, so controlling sheet flow of water is paramount to avoid washing the driveway out.
Profile of it has proven pretty good, so I try to do just a little bit a time to prevent changing the drainage pattern too much at once.
Reactions: 6 users
Chanceywd
Mar 26, 2021
680
598
central ny
Maybe some stock on both sides welded to your angle that has holes lining up with the weight hole.
Just a thought seeing it assembled so far.
Bill
JimDeL
Aug 31, 2022
337
375
Austintown, Ohio
Mounted a little toolbox to the BX using the SMV hardware. Turned out pretty good. Time will tell. Nice to have a place for some channel locks, gloves, rags, grease, etc.
I used a similar (50 Cal) box on mine, but removed the SMV hardware, bolted the box sideways to its bracket, and remounted the SMV hardware to the outside of the box. Mine's gray to match the ROPS.
DirtbagSurfer
BX1880, LA344, BB1248, F-350, Red Heeler.
Feb 14, 2024
Pacific Northwest
If my SMV bracket ends up bending, I may have to change plans and do it your way. Your set-up can probably handle more ice and cold beverages. ;)
