Kubota l3350 help on finding cylinder head/engine model
5,253
The engine serial and model number is stamped on the flat of the block, facing up, right beside the injection pump.
DO NOT go by any castings on the block or the head.
Buy a stock oem Kubota gasket, not aftermarket!
Should be a V1902:
Garrettl1515
B1750 B2150 L3350DT L345DT B7100HST B7100 L2201 B6200
Feb 19, 2024
37
21
Bakersfield CA
Should be a V1902:
I will check the block I really appreciate the help. But look at the difference in the head where injectors go. One is a small hole with a retainer bolt and the other is a large hole for injector
5,253
Ok you have a direct injection engine with Pencil injectors.
I was going to mention that. :confused:
Give me one min for the right head...
5,253
Rebuilt:
Used:
New:
JUMP ON IT:
And the head gasket:
Garrettl1515
Feb 19, 2024
37
21
Bakersfield CA
Rebuilt:
Used:
New:
JUMP ON IT:
Wolfman I really appreciate the help! This forum is so helpful! But man I was liking the aftermarket eBay one for 350$, the genuine Kubota is 900 without valves or springs, I’ve had good luck with aftermarket in the past. I think I want to go that route, any advice
Garrettl1515
Feb 19, 2024
37
21
Bakersfield CA
Rebuilt:
Used:
New:
JUMP ON IT:
Im not sure if an aftermarket one exists I can’t seem to find one
5,253
Oh and thew O-ring too
5,253
Garrettl1515
Feb 19, 2024
37
21
Bakersfield CA
No no aftermarket on that one.
I would get this one if it were me:
Looks like that’s what I’m going to have to do, would I just reuse my valves and springs?
