I want to add rear remotes to my MX5800 using Summit Monoblock Hydraulic Directional Control Valve, 4 Spool, 4 Float, 11 GPM.
To keep it a clean install, I want to connect hoses from the Summit valve block to the hydraulic ports under the seat, where the factory rear remote valves would normally mount.
I would also like to connect my backhoe there, rather than running it to the loader valve and block under the right side floorboard.
What do i need to do to connect to the hydraulic ports under the seat? Is there an adapter for this use?
If there isnt an adapter, what do i need to do to make one?
Thanks
Thanks
