B7100 hydraulic toplink
TerryC
GR2120, B7100, BX2670
Apr 21, 2017
11
Aitkin, MN
Is there a parts kit or instructions on adding a hydraulic top link to a B7100? Is this possible?
Thanks
SDT
multiple and various
Apr 15, 2018
3,100
948
SE, IN
Thanks
It is possible but you will need a remote hydraulic valve unless you choose to operate it from a FEL valve.
You can probably still buy the remote valve from Kubota.
1,077
See FitRite Hydraulics for a source for custom cylinders. He can also supply the valve.
See this thread for the method of starting as mentioned above
5,475
This would be a 100% custom DYI project.
If you have a B7100 with the hydraulic block in front of your right foot then you can get an adapter block from @torch and tap into the hydraulics.
The valve can be a generic valve from places like Surplus center, you will need open center and power beyond.
Might even find a cylinder there, you will need to know extended and retracted length.
Hose can be ordered from mutiple sources, like discount hose.
You will need to add a "lock" to the cylinder to keep it from drifting.
You'll more than likely need to have the ends of the cylinder altered to fit the mounting points.
3,198
I used this method…then purchased a hyd toplink cylinder/hoses separately. Pulling the knob lets me use the FEL joystick to adjust the toplink…then restore the knob to the closed position to return the joystick to loader-control. (That second action is easy to forget tho’…) :rolleyes:
They now also offer a TopLink set up: https://www.tractorinnovations.com/toplinks
3,604
Thanks
Very possible but no kits that i know of. You will need to buy anappropriately sized toplink, Then its a matter of hooking up a control valve and adding rear outlets if needed. Instructions are pretty simple. Do you have a loader?
TerryC
Apr 21, 2017
11
Aitkin, MN
Yes have a loader
3,604
Then all y
Yes have a loader
Then all you need is the top link, an inexpensive control valve, a few hoses, and a pair of quick connect outlets. You also need to pick a place to mount the valve. My personal choice would be bolt it to the top of the right fender. Its a convenient location and easy to do. And I would not do just one set of remotes - I would do two. The incremental cost for the valve is coffee money and you don't have to add the outlets until later.
2,279
Dan,
Love the line - but I have a question, is that Starbucks coffee or the better half's coffee? One is overly expensive and the other 50 cents! :LOL: (y) ;)
3,604
Dan,
Hyperbole Whole Bean Double Roast :LOL:
Real (subject to @hagrid metaphysical determination) numbers:
One spool: $80
Two spool : $109.
2,279
One spool: $80
Two spool : $109.
Two lumps of sugar sounds perfect! (Spools) - I would, if doing that def go for 2 !
wp6529
B7100DT
Oct 31, 2023
152
96
TX
Having a B7100 and a handful of attachments of various sizes and weights, my question is why? Adding a hydraulic top link will cost hundreds of dollars and with all my adjusting be it back blade or brush hog I've never had an issue just reaching behind me and turning the top link by hand.
3,604
Adding a single rear remote will cost $200 and is a useful addition to any tractor. Take maybe am hour to install and can be used for much more than just a top link.
A hydraulic top link is another $150. Its utility is more debatable but far more think it is worth the cost than dont't. I for one am quite sure I cannot adjust the toplink on any of my tractors, including a B7200, from the seat.
Most people can make those sorts of cost/benefit decisions for themselves when armed with the facts.
