I have a leak from what looks to be rivet covered holes on the side of the flywheel housing on my Kubota L355ss. There are four such holes right under the clutch arm. I am also noticing fluid leaks around the column under the steering wheel, leaking onto the dash. Perhaps related? Any suggestions on what I can do to address this? The leak from the flywheel housing is pretty significant so I hesitate to use the tractor much until it is addressed. Appreciate any advice! Thank you!
