Thanks DustyRustyMost likely something is loose and banging around. Since the tractor is new, let the dealer deal with it. Most likely something wasn't tightened when it was assembled. I have no idea what the second picture is of, but that looks like the item that is causing the banging.
That is why the fellow that you bought it from sold it. He couldn't figure out the banging either!Thanks DustyRusty
the second video is from bottom of the tractor, it seems what joins the shaft with the front axle
the tractor is used 1979, I mistakenly mentioned new B7100; I meant recently I got it
Could beThat is why the fellow that you bought it from sold it. He couldn't figure out the banging either!![]()
yes, 4wd is engaged, and yes sound is happening when tractor is stationary or movingPlease advise on type of transmission, Manual or HST.
Is 4WD completely engaged.
That shaft should only be turning when 4WD is engaged and tractor moving.
If this rotation and noise is when the tractor is stationary, we need to know
This forum has a number of members with B7100 who will get around to posting.
Which Jordan? Middle east or USA
Post complete serial number.
Perhaps your problem is not with the front axle shaft but rather the mid pto shaft going to a front mounted implement.yes, 4wd is engaged, and yes sound is happening when tractor is stationary or moving
I had another look, and it seems another shaft rather (PTO maybe) than drive shaft, I disengaged/reengaged the PTO, and the play gone
below video shows exactly the shaft location:
Video 1
and this video shows it without the wiggle/play
Video 2
Jordan in Middle East, and serial number is
B7001-71659; I have posted earlier another thread, and was told it is B7100
"Since the tractor is new" ???Most likely something is loose and banging around. Since the tractor is new, let the dealer deal with it. Most likely something wasn't tightened when it was assembled. I have no idea what the second picture is of, but that looks like the item that is causing the banging.
I asked someone in my area who owns B6001, and he told me it is clutch shaft, and the spring should hold it and prevent the knockingLooks to me like the shaft coming out from the clutch that drives the hst. Something must be worn and/or need greasing. The shaft beside it with the universal drives the front axle like on my previous b7200.
It’s not new, it’s 1979 Kubota B7100"Since the tractor is new" ???
Those two videos don't seem to indicate a "new" tractor.
It seems the clutch throw-out shaft, and maybe I need to change the clutch bearing spring maybe, since mine seems a bit loosePerhaps your problem is not with the front axle shaft but rather the mid pto shaft going to a front mounted implement.
The shaft looks small like a mid pto shaft.
Without something connected to the front end of the shaft there may be a U joint banging against something.
I understand,........ but poster #13 described it as being new.It’s not new, it’s 1979 Kubota B7100
