IF you can get a small screwdriver and place it here - it should come apart. OR are you trying to remove the entire connector from the sensor? Not sure the latter is possible.How do you remove the plastic connector on the water temp sensor of L3301??
Ok I'll try that.IF you can get a small screwdriver and place it here - it should come apart. OR are you trying to remove the entire connector from the sensor? Not sure the latter is possible.
Yep. A hair dryer application might be useful.Doing it in a warm environment if possible is best IMHO.
It has been my experience that cold/frozen "plastic" parts are much more prone to "accidental breakage" when prying or squeezing.
