The Original Tractor Relief Tool™ a Must Have!
TractorReliefTool
Vendor Member
MX5400 L4701
Nov 23, 2023
Central Coast California
I'm here to make your Tractor Life Easier!
What's up guys. Fellow Kubota Owner here. I manufacture a tool to release the pressure on your tractors hydraulic couplings. I developed it out of my everyday use on the ranch with the grapple on my tractor and the constant fight putting it on and off. Check out the website or buy on Amazon. This tool will seriously make your life easier, I use it several times a week changing implements. Glad to be here!
Please go to website to figure out how to confirm your size. Or feel free to email me!
Release with ease!!!
www.tractorrelieftool.com
cthomas
LX2610 HSDC
Jan 1, 2017
863
572
La Farge Wi
I have had issues with my front end loader. I have to take it off when installing the snowblower. Currently to lazy to go measure, so anyone know what size for the LX2610?
TractorReliefTool
Vendor Member
MX5400 L4701
Nov 23, 2023
Please take the time to measure the diameter when you get a moment. There is no rhyme or reason on coupling sizes/types it seems. You can email me the diameter and pic of coupling and I will verify for you.
InTheWoods
B7510/FEL, B7100D, ZD18, ASK-R130
Nov 17, 2023
80
35
Indiana
Curious why this is needed. Is there a reason that Kubota's procedure (basically shut off the engine, and push the hydraulic control lever through all its positions) doesn't work? I've had no issues.
ken erickson
Nov 21, 2010
1,009
1,576
Waupaca Wisconsin
Many times , it happened to me, that it is the lines on the grapple. I took my grapple off in the fall, it was a cool day. It was warm day in the spring when I went to reinstall and I could not for the life of me overcome the pressure build up in the grapple lines. I had no other tools and ended up unscrewing one of the couplers to relieve the pressure.
TractorReliefTool
Vendor Member
MX5400 L4701
Nov 23, 2023
When implements sit in the sun they build up pressure when disconnected, which make it extremely difficult to connect to the tractor side hoses. While the toggling of the joy stick etc may work for the tractor side, there are just as many occasions that it does not, and it does not relieve the pressure on the implement side.
armylifer
Mar 26, 2013
1,958
702
Thurston County, WA
I like the idea of your Tractor Relief Tool. It seems to me that it not only makes it easy to relieve excess hydraulic pressure, it appears that it would also prevent damage to the coupling when using it to relieve pressure in the lines.
