show off your "on" tractor toolbox
GrassLakeRon
B8200HST-DP , RC60-82h Mower Deck, Woods RB6 Rear Blade, Homemade Carry All
Oct 27, 2023
246
143
Grass Lake, Michigan
Hi all,
I have been toying with my toolbox placement on my b8200. Just would like to see your ideas......
Ron
2,617
I have/had a small ammo can mounted to my ROPS
I have to remount it though because I did not mount it with large enough washers and the "Chinesium" gave way.
Vlach7
L47 305DT JD500C
Dec 16, 2021
330
244
Frazier Park Ca
For the L 47, the 40 caliber can was the largest ammo can I could find, to hold the most. It is actually a larger cam than the 50 caliber can. Doing a search of the many times this subject has been talked about. I posted my pictures at least a couple times.
Trimley
BX23SLSB-R-1 plus additions
Jul 25, 2023
1,123
836
PNW-WA
All the ammo cans are flimsy. To include the vintage era.
I've thought of using a 5gal Jerry Can, cut down. Cut it about 12" of the bottom, cut the top off at the seam, band the top to make a lip, for overlap and retention, hinge the back, hasp (or use an ammo can latch) the front type thing. Punch some holes in the bottom. Rhino Line it.
GrassLakeRon
Oct 27, 2023
246
143
I'm thinking of a steel (4" square tube) with a flat plate to which I would bolt a box to between my rops bars. Maybe a chain box up front bolted to the frame
Soopitup
BX23S
Oct 25, 2018
336
156
New England
.40 Cal?
Or 40mm grenade?
The grenade boxes would definitely be bigger.
2,454
BX25D
plastic - the hardware cost more than the box!!
Tarmy
L2800, BH76A, FEL,box scraper
Nov 17, 2009
441
331
Lake Almanor, Ca
Just don’t drill into the ROPS. I made a base/bracket for each side so no welding to or drilling into the ROPS.
jimr63
M5-091HDC, L47TLB, L4701F, ZD1211-72, GR2120-54, RTV-X1140
Jun 24, 2015
120
47
SOMD
I installed a 50 cal. ammo can in front of my fuel tank on the M5.
GrizBota
Apr 26, 2023
1,153
735
Oregon
This is on the L3830. the idea came from @Flintknapper. Has its own frame to support it. But, I did loose some rearward visibility, really noticeable using the back blade and pretty noticeable using the brush hog.
This is on the B2601. It’s a cheap plastic 30 cal “ammo” can that replaced the dealer’s plastic pencil box. It’s good for putting trash in when I mow the county R/W in front of my field.
Flintknapper
L2350DT
May 3, 2022
1,748
2,195
Deep East Texas
Chainsaw brackets are handy aren't they. I like where you have yours mounted.
Normally, I carry just a small saw in mine, but they will support a fairly large saw...as evidenced by your application. I like it. (y)
leveraddict
Apr 1, 2019
907
588
NEPA
30 cal mounted with U bolts reinforced with washers.
GrizBota
Apr 26, 2023
1,153
735
Oregon
View attachment 115666 View attachment 115667 View attachment 115668
Indeed. I looked around and those chainsaw mounts seemed to be the best fit my application. I did cut the ears off of them and bolt them directly the top rail of the basket and the bottom rail and the independent support bracket. They aren’t going anywhere unless I hit something.
The mounting strategy fir the two saws was to leave a good view shed over my left shoulder, since I’m left eyed and to allow for a pole saw mount on the right side (design is rolling around still in my head, plus a couple other partially done projects have slowed me down).
Flintknapper
L2350DT
May 3, 2022
1,748
2,195
Deep East Texas
If you come up with a workable pole saw mount of some type, please share it here. I use my pole-saw more than anything else and would love to be able to tote it on the tractor.
Tarmy
Nov 17, 2009
441
331
Lake Almanor, Ca
I have one for using my pole saw or extension ladders. You can see one of the brackets in this picture, sorta obscuring that valve body/hose. Note how it slides into that upright tube. That J shaped piece I lift up and rotate 90 degrees so it stick out and the other is a small similar type of hook that fits on the side of the front bucket. I raise the bucket up enough to level them roughly and put the pole saw or ladder on and off I go.
GrizBota
Apr 26, 2023
1,153
735
Oregon
The concept is a hanger off the pivot point bracket on the ROPS (no mods to the ROPS, use the existing open hole) and a U shaped support that is bolted to the FEL valve hardware. The U shaped support will stick up quite a ways to allow the FEL to be able to move through the full range of movement. It will also have the upper portion removable and plug in to a lower section socket that says bolted the the valve support bolts.
Overall mounting position concept.
Rear hanger mount location (it won’t be a bungy cord), but you can see the open hole that will be employed.
Front mount location (it won’t be chunks if 2x4, that’s just to get the dimensions and orientation).
The rear hanger will only be about 4 inches long. The front support will be about 18” tall. Hence why the upper 14” will be removable when the pole saw is not mounted. The saw will be at an angle to the long axis of the tractor to allow the FEL to have full functionality (since I’ll likely have the grapple on it). It will pass over the top of the FEL lever to allow it to be usable. The “dry” fit suggests there will be plenty of shoulder room as the saw angles towards the center of the tractor such the the boom on the FEL can come up without hitting the saw.
The mount on the existing valve hardware and the socket/removable section will take a bit of thought to get right.
But if it was easy, anyone could do it. I like a good challenge to solve. I maybe slow, but I sure am slow.
