Anyone have an idea what these holes were designed to do?
2001TLB
L48TLB, 60" EA SSQA Root Rake Grapple, EA SSQA Fork lift
Nov 14, 2021
51
46
Shelton, Washington
As the title question asks, I have a L48TLB with the 72" bucket. There are two 1" holes one on each side of the SSQA bracket. I wonder if there is some specific design use for the holes?
I was thinking they would work pretty well for a 3/4" shackle, but the shackles dimensions don't allow the shackle to lay straight. The largest shackle that would work would be a 2 ton working load unit, with 1/2" pin.
Just wondering I guess....any ideas or thoughts?
Doug
NorthwoodsLife
Oct 15, 2021
1,036
983
Wisconsin
Bottle cap openers.
Gotta krack open a beer between implement change-overs. 🙂
BXHoosier
BX24
Jan 21, 2018
471
530
Indiana
Could be as simple as a place to hang the bucket when it’s painted at the factory or an alignment hole for the weld fixture.
4,690
Have similar holes on my B23S bucket, agree they're for hanging it up in the assembly line to paint and dry.
2001TLB
Nov 14, 2021
51
46
Shelton, Washington
I'll have to try out the utility of the bottle cap opener idea.
Otherwise, I think I'll pick up a couple of 2 ton, 1/2" pin shackles to see how they might work for chain picking loads. I'm not opposed to welding or bolting hooks to the bucket, but thought I would try this idea first.
Thank you,
Doug
4,920
Doug
I have the 72" 2006 Kubota OEM bucket on my 2006 L48 TLB
It does NOT have those two large holes.
Mine does have two 5/8" holes though, that are widely spaced, and are on that same vertical stiffener.
Would seem to lend credence to the painting hypothesis.
ken erickson
Nov 21, 2010
1,093
1,799
Waupaca Wisconsin
Its obvious to me that the holes are punched in at the time of manufacture as a place for the dealer to instal their inventory tag! lol,
Kidding aside, I have my doubts that they are used as a way to hang durning the painting process.
4,690
Hay Ken, you just have to become a manufacturer and figure out HOW you can paint a bucket, on an assembly line. I've seen lost of 'mystery holes' in things over the years, and they're usually place to hang whatever on the overhead chains for 'painting'. Easy one is the hole in the tip of the earth augers/ bulb planting drills. They hang them on that ,so they can be painted.
nbryan
Jan 3, 2019
1,213
755
Hadashville, Manitoba, Canada
I am making a slightly educated guess here, and it looks like those holes would be for mounting an add-a-grapple to the bucket.
Trimley
BX23SLSB-R-1 plus additions
Jul 25, 2023
1,081
800
PNW-WA
Is it possible they're having something to do with a 3rd function attachment? My 23s has the same holes.
NorthwoodsLife
Oct 15, 2021
1,036
983
Wisconsin
Could be. Or for a 4 in 1 bucket.
But I'm thinking that it's a jig alignment hole used in production.
The Evil Twin
L2501, LA526,
Jul 19, 2022
2,698
2,684
I was thinking along the same lines as @NorthwoodsLife with it.
While it may be handy for paint, the likelihood of holes punched specifically for that are slim. My bet is production related. Either before or after the SSQA bracket is welded to the bucket. Or even both.
4,690
Just checked ( OK, finally remembered to look.... ) The holes have to be for production for the BX23S 48" SSQA bucket as only 1/4" gap between them and the frame .
GrizBota
Apr 26, 2023
1,153
735
Oregon
Anyone say speed holes yet? Like the 5 Hp stickers they put on 120 Hp cars that makes them terrors of the streets.
NorthwoodsLife
Oct 15, 2021
1,036
983
Wisconsin
Thank you,
Doug
Make sure to try it with a Sapporo or Asahi or similar Japanese beer.. it is a Japanese tractor afterall.
Bud Light definitely won't work out.
Trimley
Jul 25, 2023
1,081
800
PNW-WA
Would Budlight Platinum work? That's my goto when I indulge 🤣
