I have an L275DT I’m currently putting a koyker 160 loader on. The tractor previously had a kubota KUFD210 snow plow blade on it. The snow plow valve had two hoses that attached to the block under the left side of the seat. The valve on the loader is currently set up as open center and has two hoses coming off of it like the plow valve did.
For the question:
I’ve read in the tractor operation manual that I need to use a power beyond capable valve for connecting to the block under the seat, and I know the loader valve is PB capable, but shows I’d need a sleeve and a third line going to tank. One, how was the original plow valve able to do it with only two lines? Everything seemed to work fine before. Two, if I have to use three lines, where does the tank line hook up and what fitting size do I need? Three, what does the power beyond sleeve do and look like? I think I might have one.
For the question:
