johnjk
Apr 13, 2017
1,421
1,189
West Mansfield, OH
Rock time. 100 tons dropped today. Driver doing a good job tailgating it. Need to thin out some overlap and fill some thin spots but that gets me seat time after lunch. I should be adequate with the box blade by then so I can forget everything until I get rock again
Reactions: 9 users
Siesta Sundance
Oct 23, 2022
1,430
1,727
youtube.com
If you have a business (farm?) I would strongly suggest that you try to budget for a HOT pressure washer.
I have a 50 year old Hotsy (brand), electric motor washer, with only 1,000 psi.
The hot pressure water will 1,000% out clean my 4,000 psi 13Hp Honda powered, cat pump, cold water washer.
The domestic water heater hose method will be a bit better than straight cold water, but 200 degree water, with high pressure, and dedicated burner heated water is vastly superior.
Farm. Thanks, noted.
Flintknapper
L2350DT
May 3, 2022
1,735
2,179
Deep East Texas
That driver is doing a heck of job. Looks great!
johnjk
Apr 13, 2017
1,421
1,189
West Mansfield, OH
He did good. Got 10 ton dropped by the road and 10 back by the house to finish up
5,936
No, but I think I'm gonna use the drain off the water heater next time, probably put one those in line screen gaskets that are on sprinklers so the pressure washer doesn't suck any debris from the water heater.
You can't, pressure washers do not do well on hot water you will seize up the pump.
4,957
You are fortunate to have found a driver who knows how to spread material!:)
Siesta Sundance
Oct 23, 2022
1,430
1,727
youtube.com
Nice.
Here it's cheaper to get the belly dump ~22 to 23T each load, $400 to $500 dependant on dsl costs, just got to inform driver to set locks at the lowest setting, and drive faster.
RMS
LX2610HSDC, RCR1260, PFL1242, LX2963, RB1684, WC-68,Flail Mower,Grapple, Z421
Sep 26, 2021
211
392
Buckfield Maine
Since I do better reading from a physical document I took a pdf of my wsm to Staples and had it printed out. It wasn't cheap but still less than buying one through a dealer.
Old_Paint
Dec 5, 2020
1,703
1,663
AL
I'd just be happy to get the WSM. Where'd you find that?
GrizBota
Apr 26, 2023
1,153
735
Oregon
This morning I helped the neighbor get rid of a couple pine trees that were hanging over his garden area. Used the L3830 and grapple to take the brush up to my burn pile. Tried to use the bottom tines of the grapple to tear up a mound with a bush (which had been removed) to try to uproot the thousands of woody stocks. Ended up doing a fine job of removing the dirt from around the woody stocks (we lost that round).
4,957
We think alike!
I actually have 2 WSM's for my L48 TLB.
I keep one in FL to refer to when I am there, and one in New England, where the machine is.
I really should sell the WSM in FL, but over the Winter I do find it handy to check on OTT postings.
How did I come to wind up with two.?
While in FL for a Winter, I forgot that I actually already had the manual.
The dysfunction is commonly called......Old Age!
S-G-R
LX3310
Jun 17, 2020
1,070
2,167
PEI Canada
My heavy hitch arrived today. Opened the box and put in the lower pins. After how the rest of my day went I didn't go any further.
DaveFromMi
L3901 RCR1260
Apr 14, 2021
605
526
Indiana
My oldest son came out to visit today. He wanted some seat time, so I set him up.
Reactions: 8 users
3,534
water service from h*ll today. The bank was so steep there was now way i could climb it with runner tracks on wet grass...dug from both ends and finished in the middle in a very strange position as the trench started to collapse when I jumped it.
also, when the tech cut the old galvanized water service, the homeowners/ power went out...WTF? Power was overhead so what just happened. Then it dawned on me that we basically cut the house ground and he must have an open neutral somewhere. His power was "restored" when we bonded the ground to the new copper water service line...yikes man.
anyway, just a few pics. Note, the pics of the bank don't look nearly as steep as it was. Trust me, it was my a$$ in the seat.
diggy:
connected, "cleaned up" a bit. Got out of there.
oh, here is a fun one:
Reactions: 8 users
ajschnitzelbank
Aug 24, 2021
200
411
Rensselaer County NY
Today I used the tractor to help a neighbor plant some trees, and to get my kids new play set (Craigslist free score) out of my truck and in to the yard. Both things could have been done with some muscle, but what fun would that have been?
Reactions: 10 users
