Overheating issue
PoppyW01
Kubota G2160
Feb 17, 2019
Fayette, Alabama
Good morning,
I have a G2160. got it 4years ago after it sat in previous owners yard for some years. Has 460 hours. Last year it started running hot in an hour, takes 2.5 to mow my yard. I know it is running hot , not due to the light but watching water and steam blow out of the radiator overflow tube from the plastic container. I removed the thermostat and didn not help. New water pump seemed to help last year. This year it runs 30 min before overheating. Brohter in law is a diesel mechanic, his over the phone diagnosis is a likely head gasket. No water in the oil or vice versa but he had me put the overflow yube in a bottle of water and see if and when it bubbles. It starts a small but steady stream of bubbles about 10 to 15 seconds after starting. Opinions and if its the head gasket, difficulty level for replacement?
Thanks
3,060
Clean the rad ,,DO NOT USE A PRESSURE WASHER ,,, check the thermostat, drain everything flush and refill,, always check the simple things first
Flintknapper
L2350DT
May 3, 2022
1,701
2,138
Deep East Texas
Plugged radiator ??!!???
rather doubt the head gasket as no fluids are being mixed.....
Though HG failures often manifest that way (fluid mixing) it is not the only way a HG can/will fail.
A steady stream of bubbles in the coolant upon start up is a near sure sign of Head Gasket failure (compression to coolant).
ve9aa
Apr 11, 2021
1,202
980
NB, Canada
Have you cleaned the (pull-up, removable) screen in front of the rad on a regular basis?
2,332
based on your last sentence ........ " if and when it bubbles. It starts a small but steady stream of bubbles about 10 to 15 seconds after starting "
I would say you have a blown head gasket - your BIL should be able to help you fix it - need some simple tools and a torque wrench. A leak at the right spot on the gasket will pump combusted air into the coolant
and show up as bubbles in the radiator.
PoppyW01
Kubota G2160
Feb 17, 2019
Fayette, Alabama
Thanks all. I have cleaned the radiator externally and the screen. The insides of the radiator is difficult to see except difectly under the cap. Those holes are not plugged but not as wide as I think they shoild be. Id rather not but a $200 radiator just to find I still need a head gasket, and vice versa! I could need both however.
I appreciate the input, continue as I work on this. I do have a shop manual so once diagnosed, I'll try to tackle it.
THANKS!
6869704x4
L45TLB, 49 8N, 57 641, RTV-X1120D, Z422
Jun 29, 2011
255
294
SE, NM
See if you can rent a radiator pressure tester at O'reillys or autozone
$90 at HF
cthomas
LX2610 HSDC
Jan 1, 2017
863
573
La Farge Wi
See if your BIL has a combustion coolant detection kit or buy one. The Block Tester is a used to detect the presence of exhaust gases in an engine's cooling system, typically caused by a blown head gasket or cracked head or block. It comes complete with enough fluid to conduct 16 tests. There are no additional tools needed, and no need to tap into an engine vacuum source. Works with virtually any liquid-cooled internal combustion engine or generator with a closed cooling system including: gasoline, diesel, propane, natural gas and other alternative fuels. Large, single-chamber design provides greater accuracy and uses less test fluid.
It is $36.99 and free shipping if Prime member.
5,657
Your chances of a blow head gasket are 10 to 1, your chances of a cracked head 2 to 1.
These engines are know for cracking the heads.
Easy enough fix, pull the head and replace head, head gasket.
2,592
1,362
$90 at HF
I'd be careful there. Before you pressurize the cooling system, remove the injectors or glow plugs and turn the engine over to remove any water that may leak in. Otherwise, you could hydrolock it and cause more issues.
Jim L.
835
115
I agree that it is likely that the head has cracked.
When these engines overheat they need correction immediately. Continuing to run until overheating, just overheating a little and not even busted needle on the gauge overheating, the cumulative result is a cracked head.
Make sure to know how to clean the surface of soft aluminum - put a scratch in the metal and the new style gaskets will not seal.
Calibrated torque and proper sequence of turns and sets on the head bolts very important.
2,748
1,247
The cylinder block and cylinder head are cast iron.
6869704x4
Jun 29, 2011
255
294
SE, NM
Since we're spending the OPs money a cylinder leak down tester would narrow it down a bit.
Jim L.
835
115
"The cylinder block and cylinder head are cast iron. "
Sorry for not conveying that idea properly. What I meant was that things have changed for those of us who are old school. Techniques that were used in days past do not work well with today's machines. Gaskets are one of those. The material these days is completely a different animal, and behaves differently. So easy to get wrapped around an axle following old techniques off of youtube if it is the wrong video.
