Hydraulic Top Link for L3560
LenLar57
L3560-LE
Apr 21, 2022
9
North Carolina
I have a Kubota L3560 with rear remotes.
I want to try a Hydraulic Top Link. Anyone have any suggestions or recommendations?
MtnViewRanch
853
293
Lakeside Ca.
A 21"-31" working length should work well for you.
I'm sure something close and you will be good to go.
You can probably get by with a 2" dia cylinder, but I recommend a 2 1/2" unit with a 1 1/2" dia rod.
Tropical Jack
Kubota L3301 w/ FEL & BH, tilt and trim, chipper, box blade, grading blade
Hi,
I have an L3301, and got my hydraulic top link from Agri-Supply. I wanted a top link capable of “float”. Accordingly, my valve allows for float, and my cylinder does not have a check valve.
You can also get a top link hydraulic cylinder with a check valve.
The best hydraulic cylinders available are custom made by Fit Rite Hydraulics. You might want to look on his website; there is a lot of good info there.
Jack
PortTackFarm
L3560 LE (ROP's) w/ LA805 FEL, LP RCF 2072, BB2572 and WoodMaxx WM-8H
Jul 2, 2021
145
157
The Ville and The Farm (KY)
FitRite Hydraulics - pricey but well worth it. Biggest drawback is time, probable at least 30 weeks out, but the demand and wait time tells you how good they are.
TuckR
L3302, BB1266, STB1072, SGC0660, GS1560, post hole digger
Mar 6, 2023
12
Spokane
Hi,
Jack
Hello, I have the L3302 and was just going to order this. Did you get the 2"x8"? Seem to be working okay?
ScottHam
Kubota L3560HST-LE 4WD; R4 tires; Armstrong Ag BRG-mini grapple; 1272 box blade
Jul 9, 2022
35
89
Texas Hill Country
I just installed a hydraulic top link on my L3560 a couple weeks ago. I contacted Agrisupply, and they sent me a helpful email indicating the best model for my tractor. I ordered through Agrisupply, and the hydraulic top link arrived in 3 days, it was easy to install, and it works perfectly.
LenLar57
L3560-LE
Apr 21, 2022
9
North Carolina
CAPT Seabee
Grand L5460
Dec 28, 2022
Bonners Ferry ID
I'd add the larger diameter the better. Also recommend a locking block model. Why? If you have a brush hog lifted for transport down the road, it will gradually work its way down due to the momentum generated when you hit bumps. That's a lot of torque that translates to pull on the cylinder.
texas42
26
14
Aubrey, TX
jajiu
Jun 5, 2016
456
112
Rowley, Massachusetts
I got mine from Fit Right Hydraulics and the wait was worth it, I've had it for several years now and it works GREAT!
MtnViewRanch
853
293
Lakeside Ca.
What are your thoughts on a hydro toplink for the L6060 Grand? I did look at Fit Right, however I am not able to wait the extended lead time as I am in need of it very soon.
I am looking at the kits on amazon: (Cat 2 option). 18 15/16 x 27 3/16. or 19 11/16 x 28". or 22 3/8 x 33 1/2"
What are your thoughts?
Look at the following link and determine what will work best for you from what is readily available.
Ideally mid stroke has the implement close to level front-back.
For your application, I normally recommend a cat 1-2 unit built using a 2 1/2" dia cylinder with a 1 1/2" dia rod having a working length of 23 1/4"- 35 1/4". You will most likely be better served having a check valve on the unit to prevent cylinder drifting.
I don't believe that you will find this unit as an off-the-shelf unit. Maybe you can find something close without too many compromises.
Good luck.
