About two weeks ago I used the L185DT to mow the driveway and an area that had been a garden in past years. Parked it in the barn and Friday went to get it out to mow again. I lifted the front dozer blade up and when I tried to lift the old Woods mower on the rear it would not lift up. Toped off the fluids and tried it again. Still no lift. Took the hydraulic filter out and it did need cleaning. Cleaned in diesel, and reinstalled. Replaced fluid and still no lift. Can't be the pump as my front dozer blade can lift and even has down force to lift the tractor up off the ground. Any other areas to look at? Should I go ahead and drop some bucks for a new filter just to be sure it is not still clogged after cleaning it?
