RPMs up and down
KS23
B2601, RB1672, LA435
Oct 15, 2022
11
Wyoming
It is 1 degree right now, I started my B2601, and let it idle for about 5-10 minutes (no block heater) then when I began to blade our drive. Within the first 10 feet it began to drop in rpm, so I stopped, increased the throttle a bit and began again, the rpm's just keep revving up and dropping down, even when at a stand still. I was barely able to get it out of the drive and back out of the way. We do use a diesel additive to avoid gelling. Not sure why it is revving and dropping rpms. But I cannot blade my drive with it like this...any help is appreciated.
4,740
I agree, fuel gelling problem. Also, consider a block heater for the future and a custom blanket to insulate the engine from the cold. Your tractor just like you don't want to be out in the cold without some protection from the wind chill. Get some Power Service Diesel 911 and put it into your fuel tank and run the tractor at a high idle until you get it through the entire system, otherwise, your tractor is going to freeze up and not want to start at all.
armylifer
Mar 26, 2013
2,019
752
Thurston County, WA
Your description of the issue is a classic one for fuel gelling. Try using Power Service in the white bottle. One ounce for every three gallons of diesel works for me all the way down to -20F.
Mark_BX25D
Bx25D
Jul 19, 2020
1,689
1,199
Wind chill is a measure of perceived temperature on exposed human skin. It has nothing to do with inanimate objects.
4,740
I was referring to the "other" wind chill, you know the type of cold that chills you to the bone, not the "wind chill" that the weatherman refers to in the weather report. Time to chill out. :)
KS23
Oct 15, 2022
11
Wyoming
Ok, op here. I started it again and let it run for 30 minutes. And problem was solved. I did want to point out that it does have the preventative in the fuel to avoid gelling. Also thank you to those that responded.
4,740
You might be using it, but not in sufficient quantities to prevent the gelling of the fuel. When I dose my tractor, I overdo it because the cost of the preventative is a lot less than the aggravation of not being able to use my tractor when I need to push snow. Last fall I bought a case of Power Service from Amazon inexpensively.
I drove diesel cars for decades, and in the old days gelling was a big problem and there were no treatments like we have today. Back then I had a steel tube device that you put into the heater hose line and it was wrapped with a steel tubing spirally wound around it. Once the engine was warm, the heat from the engine would warm the fuel before it made it to the injection pump. Worked quite well unless the fuel in the tank had gelled to the point that it wouldn't flow.
Mark_BX25D
Bx25D
Jul 19, 2020
1,689
1,199
Maybe the treated fuel was in the tank and hadn't reached the pump and injectors?
RBsingl
Jul 1, 2022
409
428
Central IL
For the treatment to work well, it has to be added and the fuel well mixed LONG before it is cold enough to begin dropping out paraffin. And Power Service should be stored where it is fairly warm because before it is mixed with diesel, it can gel in cold weather.
And if you have diesel that has a very high amount of soy, then you will need a far heavier dose of anti-gel because soy creates issues at a much higher temperature and it doesn't respond to anti-gel treatment as well as pure petroleum diesel.
My diesel generator has a metal cased fuel filter much like an oil filter and it has a 120 VAC heater wrap around it that comes on when the generator is running; probably not necessary since the genset is in a barn that keeps it a bit warmer but I am taking no chances when I really need the generator in cold weather.
Rodger
jkrubi12
B2601/LA435/QA54"/BH70/B8160box/BB1254/PFL1242/SGC0554/WC-68 Chipper
Sep 24, 2012
397
289
right coast
I routinely 'overdose' my diesels with fuel treatment(s) since it states on the container label that there's no downside to larger added quantities. I believe it's necessary to get the treated fuel introduced to the entire fuel system to ensure adequate protection.
As far as warm-up idling, I would suggest trying to slightly increase engine speed at some reasonable point after startup to assist with engine warm-up. It would also be a good idea to 'warm up' the hydraulics through a pre-operation actuation ritual; this process may speed up the overall readiness of the entire tractor.
One thing I have learned this winter (first with a tractor) is that my B2601 doesn't like to be outside in cold weather! :oops:
4,740
Rodger
Yesterday I opened the case of Power Service (white) and it has been in a very cold garage for months. I filled the generator at 28* and poured in some Power Service. the Power Service showed no sign of gelling. For the Power Service to gell, it would need to have paraffin in it and there would be no logical reason for the manufacturer to produce a product that counters the effect of paraffin in their product.
Now, for diesel having a large quantity of "soy" in it, I can't comment, since I have never experienced soy in any diesel that I have purchased. If you are referring to biodiesel or renewable diesel those are entirely different products, and yes they are commonly derived from soybean oil.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
608
463
E.
I strongly disagree, some book learned expert may say on the internet windchill def'n may not impact inanimate objects but real world where I live windchill has huge effect.
Starting my tractor yesterday at -30 that was stored in the unheated machine shed so no windchill (no wind) was easy with about 2 hours of standard block heater being plugged in.
If outside where it was very windy I would have had to leave it plugged in all night PLUS tarped with a construction heater blowing for maybe 6 hours.
So my tractor is inanimate AND my tractor sure does care about windchill as the wind strips to heat away quicker than it can be added unless more is used and protection added.
Not a perceived difference but a real difference. Maybe some internet definition says no effect on actual temp. but inanimate objects like my tractor sure care a lot (as well as the tip of my nose and finger tips)
Cheers and merry Christmas
Mark_BX25D
Bx25D
Jul 19, 2020
1,689
1,199
Oh, you mean someone who actually understands the definition of wind chill?
What you are describing is not "wind chill". It's a matter of transfer of heat, which is a very different matter. It's well understood by those "book learned experts".
Using the term, "wind chill", to describe something that is NOT "wind chill", is a error, not a superior understanding gained through personal experience.
" Wind Chill is a term used to describe what the air temperature feels like to the human skin due to the combination of cold temperatures and winds blowing on exposed skin. "
nbryan
Jan 3, 2019
1,224
761
Hadashville, Manitoba, Canada
Wind chill has been described as watts/sq meter here in CA, which tells me that the ability of moving air vs still air to remove heat from inaminate objects at a temperature greater than the air in its path is what "wind chill" means.
Then CA meteorogogists changed to a "feels like" wind chill scale from W/M², saying "feels like" more accurate.
Go figure.
A tractor out in a cold wind will cool faster, and warm slower than in a still space at same temperature.
I'd call that wind chill.
Mark_BX25D
Bx25D
Jul 19, 2020
1,689
1,199
By whom? I quoted the source. It's not open to argument any more than the definition of east or west.
That there is widespread ignorance on the subject is certainly true, but that doesn't change the definition.
nbryan
Jan 3, 2019
1,224
761
Ok, from Windchill is not a temperature! which I found because I'm a prairie guy and easily remember the watts per square meter windchill values being used.
That has changed obv, but as far as open to arguement your comment kind of irked me.
"Before 2001, the Prairies used a windchill index that was given in watts/sq metre (e.g 1800 W/m2) This was a more scientifically valid measure of what windchill actually was.. a rate of cooling, expressed in the amount of energy loss in watts per square metre of area. However in 2001, the windchill was re-calculated and standardized for all of North America to the windchill index we use today, which was mainly based on the more common "equivalent temperature" index being used in Southern Ontario and the United States. A survey conducted at that time showed that most people found the watts/sq metre unit "too technical" a term to fully understand."
Just because you quote "a source" does not make it the whole truth or complete the picture.
Mark_BX25D
Bx25D
Jul 19, 2020
1,689
1,199
I quoted the source of the term, you quoted a random blogger.
And that random blogger never says that applies to anything but humans. That is the context of his discussion.
MapleLeafFarmer
Dec 2, 2019
608
463
E.
I will preface this by saying I am probably a bit older than most, have little to no new book learning, and I live in the real world. What I speak of is only from learned experience.
When its -40 outside, a sharp / clear blue sky day with no wind, I love spending it in my woodlot. It’s my personal slice of heaven. I feel good!!! . Most of my tractors run well, my wood processor runs well (except the odd occasion the hydro infeed freezes up), the logging winch pulls as it should, my dog spends the day next to the fire off the ground, but being totally honest my chainsaws hate it except the newer electronic ones.
Now throw in a stiff wind and nothing is happy. My hands and feet get cold, only my L Kubota seems to operate well, the wood processor screams at me to stop putting wood through it, and my chainsaw often won’t let me close the snapped filler caps. My dog sucks up to the wife and spends the day sleeping in the big bed.
When it’s cold and windy out there it’s just too chilly for my stuff to work well. My body, my equipment, my dog all hate the chilly wind.
This is just my real world experience. Wind chill affects me and my equipment making my little slice of heaven something much different. A good time to spend at the coffee shop listening to the grain farmers planning arguing about their spring strategies.
Happy New Year All!!
Orange man hero
LX2610HSD
Mar 12, 2021
343
42
Wasilla, Alaska
I had this happen the other day. It was only about 25 above but with a wind chill I shut off the tractor and in 10 minutes it would not start again. Usually, it is double that time or more and it will start
