I believe this chis cotter pin belongs on my BX 1880. Can anyone ID it?
I don’t remember all of them, but I believe as DD mentioned above, check the loader frame / stand. I don’t remember but does BX have pins/locations on the 3 pt linkage? Many tractors have that. Then also the solid bar for trailer hitch off the back can also have a cotter pin. I am not sure it helps but those are three places I can think to check.Why not keep it a mystery! Just wait for something to fall off then you will know![]()
Nope, the ROPS pins and hair pin retainers are held on with steel cables so they don't get lost. It is possible to break the steel cable, but not very likely. What is pictured in the 1st post is technically a hairpin hitch clip.I'll throw one more into the guessing game...ROPs pin?
That's Ralph, Martha's youngest. He's quite the wanderer.I believe this chis cotter pin belongs on my BX 1880. Can anyone ID it?
But they will not have that nice bend to them!Ha. It's bent... You can get a dozen of them from TSC or a hardware store.
My B7500 HSD-R has two small pins like this under the floor deck on the right side. One is for the throttle linkage and the other is for the foot pedal. They are both small and metric. The throttle pin is 1.2mm diameter and the foot pedal is slightly larger.I believe this chis cotter pin belongs on my BX 1880. Can anyone ID it?
