Kubota L3901 dtc P2294
Randyari
Kubota L3901
Sep 7, 2022
Costa Rica
I need help, I'm from Costa Rica and there is no Kubota dealer here. The problem is with a Kubota L3901HST
Series 66329, presents the fault code P2294, the tractor starts without problems, works about 2 minutes and turns off, then starts again without problem, in the work manual of the model there is no reference to this fault code, analyzing it as a generic fault code, the literature refers to problems with the MPROP valve (scv). I did the tests on the valve and the injection rail pressure sensor and these were the data:
Presure Sensor
0.31volts in ignition
0.81volts at idle
2.1volts in full acaleration
MPROP Valle (scv)
33.0 Ohm valve resistance
36% Work cycle (duty) at idle
According to the technical data of this model, all the tests indicate that both components are in optimal working conditions, I have no answer as to what is wrong here. And I don't know what this code P2294 refers to and how this fault is generated.
2,954
1,627
Presure Sensor
0.81volts at idle
MPROP Valle (scv)
There's no P2294 listed in the WSM, but P2293 is listed twice. Maybe that's a typo and P2294 is related to 'Pressure limiter abnormality'?
GeorgiaBoy81
Kubota L3901
Feb 26, 2025
georgia
Just wondering if you ever had any luck fixing this issue. Im having the same issue and no luck clearing code or finding any information on this. THanks
