After getting the kit to fix the broken relief valve ( see my loader problem post ) on our 2012 B2620, and get it installed the loader works fine in all operations, however now the bucket droops with or without a load ! I will be checking to see if it is in one or both of the cylinders for curl or dump. If it is not in the cylinders where should I check next? It is full of Hydro oil and at operating temp.
I am also looking for the location to add a shim to boost the lifting capacity of the bucket.
Thanks.
Thanks.
