BX 3pt Tilt cylinder?
davidbham
BX2670 w RCK60B mmm and LA243A fel, Kodiak 48" bush hog, 48" box blade
Jan 18, 2011
15
Whitesburg, TN
There is an EBay listing for a level tilt cylinder - Kubota b8200 9200 side link hydraulic leveling tilt cylinder Tisco Ts hsl 2202 for $121.
Has anyone tried this on a BX? It looks close enough to work and the price is right.
5,055
I would first want to know both the extended length, and the retracted length.
davidbham
Jan 18, 2011
15
Whitesburg, TN
Look at the last posted pic on the ad. It shows specs of 11 7/8" to closest hole on bottom clevis. I measured my link at app 11 3/4 center to center. I extended my link to about 15 1/2", so it gets maybe 1/2 inch more extension than the cylinder, which is listed as a 3 5/16 inch stroke.
By the way, the $266 price listed on the spec sheet is not what the seller is asking. He's asking $121 w free shipping.
2,911
I think that is likely a good deal. But the cylinder may be the least expensive part of the installation, other than hoses.
I am sure you understand the costs of the control valve(s). If you do proceed consider getting two rear remote valves, then you can add a top cylinder later easily...
davidbham
Jan 18, 2011
15
Whitesburg, TN
I added the kubota remote kit several years ago, giving me two rear remotes. I have a top cylinder, from a previous B7100HST. I just haven't found a tilt cylinder.
I went ahead and bought the HSL2202 cylinder from ebay. The short answer is no, it is not a drop in fit.
The upper holes are too small and need to be at an angle to make everything work. If I have this modified to work (I don't weld), I'll post pics of the result.
Harold and USPS did a great job of getting it here. I ordered it late Tuesday afternoon, received it Friday, super service.
