Good afternoon. This may be the first post I've had on this particular forum. I tried doing some searching and probably know what the answer is but wanted to ask before spending the money.
I'm looking for a Root Rake style grapple for my new L6060. I've looked at the EA Wicked Root and the LP SGC1060. I wasn't impressed with the SGC1060 compared to other grapples I've had in the past. I know you want to keep the weight down on a CUT, i get that but the SGC1060 sure looked like the teeth would be easily bent especially if you were back raking with it. The SGC1560 is much better built but weighs over 800lbs and im afraid that is a lot of weight hanging out there in front of the L6060.
Looked at the 60" root rake from Titan- palletforks . com (i know a Chinese grapple) but I'm just doing research and want to buy the best grapple for the dollar. That one is out of stock and no idea of when it will be back in.
Any other options out there i should be looking at for the money? I'm guessing the EA is the best option but with tax and skid steer flat face quick couplers its almost $3k...
BTW I've owned an EA grapple in the past just not the root rake style. Fit, finish, everything was top notch. But we've moved 11 times in the last 16 years I've been in the military and we couldn't take the tractor and attachments with us back then. I risk that still now which is why I shy away from buying a $3k grapple. Been looking used here in SW Ohio and haven't seen too many used grapples that don't weight 800-1000 lbs.
