I did a part rebuild of my d950 (rings and rod bearings) and she smokes like hell and misfires from one cylinder (no 2) at start-up. After about a minute or so the smoke stops and it runs fine.
I know the smoke is unburnt fuel. So I'm thinking it's either compression, the injector or valve lash. However I've check all three and still can't find the problem.
The compression is good, perhaps even slightly better than cylinder 1 or 3.
I've swapped the injectors around and no difference.
I've checked the valve spacing numerous times.
Any other ideas? I was thinking of removing the injector pipes as see if the squirt out of injection pump differs to 1 & 3.
Have I missed anything else?
