MX 5200. I need to replace my clutch. Just wondering what the thoughts are on where to purchase. Should I go to my local dealership or is there a better option? Any help or advise would be appreciated. Thanks
I will be doing the job myself, just needing to know where to order partsIn trying to figure out what you're asking, are you going to install it yourself or?
If you are paying someone to install, yes, dealer is usually a better (although more expensive) option. Factory trained techs trump shade-tree techs in most cases.
Honestly, many will direct you toward Messicks and that's fine. The problem I have is shipping time and shipping COST. By time you pay for the shipping cost and then the wait time, it's quicker and in the case of a clutch job, likely less expensive to get it at a local (to you) dealer. What parts are you ordering? Have you had it apart already to inspect the flywheel?I will be doing the job myself, just needing to know where to order parts
I couldn't agree more. I too have seen clutches that didn't last 50 hours. I have also seen clutches go for a couple thousand hours or more. It's not the clutch or the breed of tractor that makes the difference. It's the type of use and how it's treated.I've seen clutched trashed in 12 hours' use (L3901). It happens.
On a lot of those tractors with relatively low hour clutch failures, I saw lots of them and 99.99% of the time they were tractors that had a loader on them (and the loader was well-used), but with gear drive (most HST's you never use the clutch). .01% were GST's or one HST that the splines were trashed. Slipping the clutch to stop/start/change direction wears it no matter how much it's slipped, it's wearing. Thus, frequent directional changes wears the friction material. Secondly use of a tractor as a bulldozer while slipping the clutch going into a dirt berm or gravel pile or pushing trees over, wears it out as well. Those were the most common causes.
Some hate HST's because of the "noise", and that's fine. But you have to be mindful of how you're using the clutch on gear driven tractors. Sometimes you're just slipping it into a pile and you don't even know you're doing it. I've caught myself many times doing it on my little MF, so I'm guilty too. Fact is, if you are doing frequent directional changes or stop/start, the HST is really a better option--from a clutch wear standpoint.
Anyway, hope you get 'er going quick and under budget.
